TwinTurbo.NET: Nissan 300ZX forum - You don't say when the vibration started. Was it thereq
Subject You don't say when the vibration started. Was it thereq
Posted by zellamay on June 03, 2011 at 11:28 AM
  This message has been viewed 83 times.
In Reply To Horrible Vibration!! posted by BufSabres on June 03, 2011 at 02:28 AM
Message before and after the new wheels/tires? Before and after the driveshaft change? If you don't remember, it will hard to diagnose. I'm assuming you've had it alligned, so tension rods, steering rack/bushings, and tie rod ends are okay. My first guess would be that driveshaft. I had one I never did like due to vibration. You could rotate it to see whether it changes anything, but the best test is to put a known good one on there. Also, I had new-tire vibration once. They re-balanced them a few times, then replaced them, and the vibration went away.
